reese avatar image
reese asked
IP22 Charger - Best Settings for Initial Full Charge
Hi…what would be the optimal setting choice or please detail the custom settings in the app to perform an initial 100% full charge on each of my new LiFePO4 batteries (230ah each) before connecting them in parallel as a battery bank?I wan’t to make sure they are both fully and equally charged.
VictronConnectbluesmart ip22ip22
uguraladag avatar image
uguraladag answered ·
When you enter the settings of the IP 22 charger and select the charger option, Lifepo4 as the battery, and 30 Ampere options, the device will automatically switch to charging mode at maximum efficiency and according to the type of battery. It will charge the battery with the ideal voltage and amper of the battery, and will reduce the charging current to zero when it is fully charged.
