Hello Community,
Just commissioned SMA Tripower X 25 Inverter. After activation of modbus tcp, SMA PV Inverter does not appear on Cerbox GX for monitoring. Can someone walk me through the process (step by step) to get this done. Thank you
Hello Community,
Hi @Adedeji Thomas,
Support for the SMA Tripower X 25 Inverters is currently in testing and will be available in Venus 3.20
All PV-inverters that use the newer Sunspec models in the 700 series (IEEE1547) will be supported in 3.20. However Limiting aka Zero-feedin is not (yet) supported on any of these.
If you would like to try it now without waiting, the instructions for how to access the release candidate are here - https://community.victronenergy.com/questions/240314/venus-os-v32014-available-for-testing.html
50 People are following this question.
