Just trying to address the registers of a Quattro with a Venus GX. The Excel sheet gives me ID 242 but this does not work? All the other registers at ID 100 are working?
Hi, had you already seen the debugging procedure as documented here?
https://www.victronenergy.com/live/ccgx:modbustcp_faq -> Advanced debugging.
And, more importantly, what error do you get on your VE.Bus requests?
Best regards, Matthijs
2 People are following this question.
