snoobler avatar image
snoobler asked
Will a multiplus not charge from AC if below DC cut-off?
  • MP 24V/3kVA 120VAC
  • LFP batteries.
  • CCGX
  • No BMS comms.
  • No assistants.
  • No virtual switch.
  • No "Ignore AC" conditions.
Only change to inverter from defaults is to raise DC cut-off to 22V.
It appears that when DC cut-off is achieved, the unit will not charge from generator when manually applied to AC input..
Is this normal behavior?
MultiPlus Quattro Inverter ChargerGeneratorac charginglow dc
Alexandra avatar image
Alexandra answered ·
@snoobler
No.
The inverter should be shut down and then on AC connect restart and then if it can (input current limit etc allowing) charge the batteries.
snoobler avatar image snoobler commented ·
Okay. so...
  1. Power off.
  2. Generator fired up and connected to AC input.
  3. Inverter in ON or charger-only mode
That should allow AC charging to commence.
