Im trying to connect some small wind generators with built in electronics that provides 48VDC to a multiplus II inverter with a 48V lead acid battery.
Im planning to use a smartshunt to measure the power from the wind generators, and the MPPT controller measure to the PV power, is it possible to run this setup and mange the battery charge/discarge and SoC or do i need one additional smartshunt on the battery?
![victron.png](/storage/attachments/64220-victron.png)
