levi1234 avatar image
levi1234 asked
victron phoenix UK socket poor design
Hello, why did the designers of the phoenix decide to put the UK socket in such a way that the inverter doesn't sit flat when the plug is in? This is quite annoying. I have however seen photos online and on YouTube of the same inverter with the UK socket rotated so the plug doesn't get in the way. Is that a correction they made? Or is there a way to rotate it myself? The first photo is my own phoenix 375 and the second picture is one I found online of another phoenix but with the socket rotated. Thank you.
Phoenix Inverter
levi1234 answered ·
I ended up opening the inverter and rotating the socket! It was not very difficult. I had to cut a cable tie near the socket to free up the cables.
iammotorhomeless avatar image
iammotorhomeless answered ·
@levi1234 I don't realy know... but I did find a picture of one, the right way up
and then another one... the wrong way
plus these two uk videos, with it the right way up
an 800 https://youtu.be/uKIj7l7sjP0?t=231
and a 1200 https://youtu.be/NOpoVhPxOJg?t=77
have you had a look inside. my best guess is, it will pop out and gently twist around
most "Unswitched Modular Sockets" look something like this on the back
levi1234 avatar image levi1234 commented ·
Thank you! I did in fact open it up and rotated it!
