aidan-h avatar image
aidan-h asked
Sun Inverter quiescent power
The Victron datasheet does not give power demand when the inverter is shut-down. This should be much lower than the 0.8 W when in ECO mode. What I need to know is the combined burden power of the PWM solar controller, Bluetooth interface and inverter when off. It is important to know when designing an unattended system.
Phoenix Invertershutdownpower
k-k avatar image
k-k answered ·
If you "have a dealer on hand"
Why not measuring with an digital amp-meter in between the batt+ terminal and the batt+ of the batterie?
if the meter have a max\min button it maybe can be used till auto-off comes up. With luck the max-value is persistent, so you dont have to watch permanently.
Phoenix Inverter product page
Phoenix Inverter Smart product page
