rickkt avatar image
rickkt asked
Victron Easysolar 24/1600 MG energy setup
Hi all,
I have one question about the settings of the following setup, an Easysolar with MG energy batteries.
Now I have the easysolar working with 6panels and 2x 12V110ah victron LiFePO4 batteries, all in an off-grid setup. Everything works in combination with a VenusOS raspberry and it works well.
Now I had the opportunity to buy 2x MG 25.6v 280ah batteries, along with the MG Master LV. The batteries are all connected to the Master and this works well, I can see them in the MG app. Now I want to connect the MG Master to the Easysolar, but unfortunately this doesn't work. I don't get this system connected to the VenusOS, not even when I connect it true a Victron MK-3 USB.
Am I missing a step here? The easysolar should be compatible with the MG batteries. Or work this only with the Cerbo?
Thanks,
Venus OSEasySolar All-in-OneEnergy Meter
The battery/BMS "talks" VE.Can NOT VE.Bus (MK3).
https://www.victronenergy.com/live/battery_compatibility:mgenergysystems
I think with the rPi you need a "Can hat" adapter.
rickkt avatar image
rickkt answered ·
Will this work with an original Victron Cerbo?
Yes, as it has all comm port types VE direct, VE BUS, VE CAN and BMS CAN.
