Marc Schmaus avatar image
Marc Schmaus asked
Battery Life not working correcly?
Hi all!
I am not sure that Batterylife is working correctly in my system.
Using 3 phase Quattro-II 5000/48 System in ESS Mode and Batterylife is activated. Last Winter Batterylife is working fine.
During Summertime Batterylife algorithmus was not necessary because of high sun power, the battery reached 100 % SoC every day. So my minimum SoC is staying at 20 % the whole summer.
The last few days sun become rare and my Battery does not reach 70% SoC for 3 days, SoC is now under 30 %, my minimum SoC still remaining on 20 %. Discharging has not been stopped and the minimum SoC has not been raised from 20% to 25%. Why?
Is it necessary that the minimum SoC is reached one time for reactivating back the batterylife algorithmus? I dont understand why my minimum SoC is not adapted accordingly to the momentary missing of sun power.
Any hints appreciated.
Sincerely Marc
ESSBMSPylontechbatterylife
nickdb avatar image
nickdb answered ·
Just to clarify, the minimum SOC is what you set, this won't change.
The active SOC is what will change.
The system will adjust by 5% per day using the following algorithm (extract from the manual):
On a technical level, BatteryLife increases the dynamic lower charge limit by 5% for each day that a good state of charge was not reached. The value is increased once a day when the battery reaches the lower limit for the first time. When the battery reaches 85% SoC on the day, the increment for that day is canceled and the limit remains the same as the previous day. If the battery reaches 95% on any day, the dynamic discharge limit is lowered by 5%. The result is that the battery reaches a healthy charge of between 85% and 100% SoC every day
There is one side note:
It raises this level by 5% each day until the energy which the system draws from the batteries during a 24hr period matches the energy being replaced
Marc Schmaus avatar image Marc Schmaus commented ·
thank you for your answer.
this is exactly what says the manual, and yes i mixed up minimum SoC and active SoC.
my question was: my minimum SoC is set to 20%, why does the active SoC not change while sun power is not sufficient and the SoC of the battery has not reach 70 % for 3 days.
nickdb avatar image nickdb ♦♦ Marc Schmaus commented ·
It should adjust, if BL is active.
Is the GX up to date on its software?
Have you tried rebooting it?
Do you have any customisations that are running- assistants, node red etc?
