James Digby avatar image
James Digby asked
Multiplus 500 hub-4
Does the multiplus 500 support the use of hub-4?
I realise the 500 doesn’t support power control or power assist so am wondering if the 500 will support hub-4 or would I need to go upto the 800 for hub-4 to work
I realise hub-4 is depreciated. I seems the only choice suitable in a marine environment.
Solar won’t quite cut it over winter to power frost protection and my dehumidifier. I’m only looking at an average load of 165w and a peak load of 415w.
Thank you in advance
James
ESSoffgridAssistantsmarine
James Digby avatar image James Digby commented ·
Does anyone know if the multiplus 500 will support the use of hub-4? Any info would be appreciated.
