2mas avatar image
2mas asked
REC BMS to Victron Cerbo Cabel DIY
Hallo All Victron lovers :-)
I need to make a cusom cabel from my REC BMS to GX Cerbo
I got the the SUB-D db9 and RJ45
i think :-) it is like this:
REC-BMS SUB-D:
Pin 2 - CAN L
Pin 3 - GND
Pin 7 - CAN H
Cerbo GX RJ45:
Pin 3 - GND
Pin 7 - CAN H
Pin 8 - CAN L
Right ??
or shall the CAN H and CAN L Crosset like TX and RX normally should?
cerbo gxBMSVE.Canmodifications
Mike Dorsett avatar image Mike Dorsett commented ·
No Can High and Can low do not get crossed. You also need to ensure there is a terminating resistor at each end. Measure can-h to can-l should measure 120 ohms before plugging in.
Experiments, Modifications and Adaptions. Mods (Modifications) can be made to Victron Software by the Community. Please use the modifications space for enthusiasts who want to push what is possible, without official Victron Support.
Cerbo GX product page
GX family product range
Cerbo GX & GX Touch datasheet
Cerbo GX Manual
Venus root access document
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
