bigmillie avatar image
bigmillie asked
What settings Victron Energy MultiPlus 12 3000 should I use for connecting to shoreline
Hi
Was hoping to charge my batteries whilst moored onto a eco mooring, not sure if its working as the amps coming in is very low,
below are some screen shots , if i need to turn the AC in to on?
Thanks for any help
multiplus ve.busvictron productsvictron community
kevgermany avatar image
kevgermany answered ·
There's nothing coming on on AC. Assuming you have a shore cable connected, look at the ignore AC in setting, should be off. Also check the input current limit. There may be a limit at the mooring which you need to comply with.
