bigmillie avatar image
bigmillie asked
Can you switch Victron Energy MultiPlus 12 3000 inverter on/off manually?
Hi
Just landed with this inverter , wanted to know if i can turn on/off without having a phone.
Have a desktop with the Victron app , but its using 220v , so have to leave the inverter on (does this damage the inverter if left on for 24 hours?)
thanks
multiplus ve.busvictron productsvictron community
Alexandra avatar image
Alexandra answered ·
@bigmillie
There is a rocker switch on the front of the inverter. It has 3 positions - on, off and charger only for manual switching.
You can leave them on 24/7 if grid connected. Obviously if inverting then you will have your battery to think of.
bigmillie avatar image bigmillie commented ·
Thanks Alexandra
do you think those switches will work if i am not using the app.
a bit risky as I havent a way to turn the 230 volt on otherwise.
Alexandra avatar image Alexandra ♦ bigmillie commented ·
Yes. The front rocker overrides all of them.
theo74 avatar image
theo74 answered ·
There are more ways to switch the Multiplus on/off/charge only
- Manually via the rocker switch [On/Off/Charge Only] on the Multiplus it self
- Remotely On/Off only, via a normal switch, connected to the green [Remote On/Off] connector
- Remotely On/Off/Charge Only plus maximum grid current set, via a Digtial Multi Control display
- Remotely On/Off/Charge Only, and all settings, via Victron app with a Cerbo GX connected
Remote options only work when the Multiplus rocker switch is physically set to On.
