bigrob avatar image
bigrob asked
PHEONIX 12/1200
I have a Phoeinx 12/1200 inverter. i have a circuit breaker 170a between the battery and inverter. when I plug in my ECOFLOW Delta 2 to rechargfe it, the circuit breaker cuts out during load. The delto 2 has ajdustable input power for recharging the battery. it seems that I can set the power input at 300 watts with no problem so far. But anything higher than that all the way up to 1000 watts. NO GO. SOMEONE PLEASE HELP AND EXPLAIN HOW TO FIX THIS PROBLEM.
Phoenix Inverterpheonix
What circuit breaker do you have?
Cheap ones are known for making problems.
A fuse is always a better solution for DC.
bigrob avatar image bigrob Matthias Lange - DE ♦ commented ·
STech 140amp and it seems that the inverter was installed at the auxilliary battery location under the drivers seat
Matthias Lange - DE avatar image Matthias Lange - DE ♦ bigrob commented ·
Do you have a link or a picture of the circuit breaker?
bigrob avatar image
bigrob answered ·
Today I connected and electric heater to the inverter and it ran for about 35-45 seconds and then cut out with a solid red light next to the on off switch.
Phoenix Inverter product page
Phoenix Inverter Smart product page
