jackson-kelley avatar image
jackson-kelley asked
Smartshunt Application in Vehicle
Has anyone used a smartshunt to monitor a vehicles starting battery? I have a truck camper that only uses 1 group 27 agm for both starting and running camping accessories. This has plenty of capacity but I would like to be able to monitor it closer.
SmartShunt
Mike Dorsett avatar image Mike Dorsett commented ·
This can be done, but you need to watch the current rating of the shunt to make sure it won't act as a fuse when you start the engine. Typically you want to look for the lock current rating for the starter motor - usually about 700 - 1000A and have your shunt larger than this.
