UPDATE 2023-10-10: v3.11 has been released officially. Blogpost will follow shortly. Change log is available on Victron Professional.
UPDATED: v3.11~2
Dear all,
For those liking all the new features, this is a small interruption. While working on v3.20, various issues have been found and fixed. And the version now available to test, v3.11~1 is all about bringing them to the market as soon as possible.
Besides fixes, v3.11 also has the new notification that tells the user that he should update the built-in MK3-controller.
Which means that the new HTML5 Marine app is missing, and few more things that were available on v3.20~7, are missing as well. In case you are looking for those files or further info see the v3.20~7 post, or download those swu files from this dropbox link.
For details about v3.11~1, see change log below. Testing it much appreciated, if all goes well we can make the official release next week.
Instructions: Venus OS beta testing & how to join/install
In case you don't know what this message is about, please start with reading this link, which explains the Venus OS beta program. Venus OS is the software running on all our GX devices, such as the Cerbo GX.
Instructions: How to post an issue?
By posting an answer below. Do please keep all findings organised: one answer issue per issue. So first check the existing threads if your issue has already been seen. And if it does, add a comment saying "me too". And preferably some more details. And in case its not listed yet, add a new Answer.
Note that Answers and Comments are two different things on this portal.
Lastly, before posting issues, preferably first revert to the latest official release (v3.10), to double check if the issue you're seeing was present there as well. Regressions require a different treatment than other issues and bugs.
And include information about the results/differences in behaviour in your report.
Instructions: Node-RED, Kevinās GuiMods, Setup helper, ExtTransferSwitch or other add-ons?
In case you are running Node-RED or SignalK, then please at least say so in your bug report.
GuiMods and other 3rd party add-ons: donāt report your gui issues here. Do it elsewhere instead.
Changes made by us can cause a compatibility issue with the GuiMods; and these betas report pages are for official firmware only.
Changes v3.11~2
Fix a few UI items related to generator start/stop run time and service interval:
- Fix toast/popup explaining that total run time can't be modified while generator is running.
- Fix service interval change confirmation toast/popup shows the old value instead of the new one.
- Service interval item now shows "Disabled" when value is set to 0.
Changes v3.11~1
- Fix Ekrano GX remote firmware update issues with VE.Can products: the remote firmware update mechanism did not accept having two ports configured with the VE.Can profile, which the Ekrano has by default.
- Fix various bugs in the gui related to generator start/stop, all regressions introduced per v3.10.
- Fix generator start stop reported run time
- Fix an info toast message is not shown when setting service timer
- Fix bug where FischerPanda gensets sometimes lose the engine values (Oil Pressure, RPM, etc)
- Show a warning if the firmware for the MK3 controller built into the GX device has not been updated yet. For details, see the v3.00 blog post.
- Various fixes to Dynamic ESS
- Solar and wind priority: fix a small bug around charge battery to 100% visualisation.
- Remote Multi/Quattro firmware updates: fix bug where the Multis and Quattros don't show on on the VRM firmware update device list if the mk3 firmware has not been upgraded.
