energy_z avatar image
Is it possible to use a lead acid or OPzS batteries for a grid tie installation with multiplus II?
I'm trying to develop a system where my client uses lead acid batteries or opz to store energy from a grid tie inverter or from the grid at night to store energy and used when need it.
Can a victron system do this? Or does it need a way to control the battery output?
The system that i'm to achieved is similar to the one in the image bellow.
Multiplus-IIbatterylead-acid
Rob Duthie avatar image
Hi
Yes it can do this, i have one my self, but use Lithium now, You will need a Colour control monitor, or a Raspi to control the ESS functions, and some energy metering in some cases.
Regards
Rob D
Rotorua
NZ
2 comments Share
By the way, there is no need to insert a module to define the battery capacity, right? Or when we define the capacity in the multiplus II is enough?
The Mulitplus has its own SOC % battery calculation internally.
Regards
Rob D
Rotorua
NZ
