John Leslie avatar image
John Leslie asked
Dual Quattro N2K PGN's via Cerbo GX - wrong DC Instance & Charger Instance
My system has two Quattro's (firmware v506). One is connected to the Cerbo (firmware v3.10) via VE.Bus and one via USB (mk3 adapter). The Cerbo is publishing the Victron equipment onto my N2K network. When I go into Settings->Services->VE.Can Port and enable NMEA2000-Out, the devices show up on the N2K network with the Device & Data instances I set. However in Charger Status PGN 127507 the 'Charger Instance' field is not set correctly. In Inverter Status PGN 127509 the 'DC Instance' field is also not set correctly. How do I set the 'Charger Instance' and 'DC Instance' fields via the Cerbo? Thanks.
MultiPlus Quattro Inverter Chargercerbo gxNMEA 2000 - N2K
Mike Dorsett avatar image Mike Dorsett commented ·
Why don't you connect the 2 Quattro's together with the VE-bus? If they are operating independently, they can still share the VE bus.
