carljgreen avatar image
carljgreen asked
How Many Pylontech Batteries Should i Get?
Hello, I have a Multiplus 24/5000/120 which currently is hooked up to a 6 x 12v (200Ah) Northstar Blue 210 lead batteries.
My (Estimated) electricity usage (annually) is 4200 kwh (@ 10-12 kwh per day)
I want to change them out for Lithium ones and am looking at the Pylontech UP2500 ones.
How many batteries should I get? (I want to reduce my reliability of the grid and reduce my energy costs and footprint)
Does anyone have any experience with these batteries and (Normal) usage on a domestic house?
I realise that I will not be totally free from the grid, but figure every little helps nowadays!
I would appreciate any help.
Thanks
Lithium BatteryPylontechstorage
chrichri avatar image
chrichri answered ·
as the max current of this battery is 85Amps I would take minimum 3 Units in parallel.
If you take only two, you will be able to run the inverter max to about 3500Watts.
carljgreen avatar image carljgreen commented ·
Thank you, I was thinking of 4?
Does that sound like it will still work to you (Charge efficiency etc).
yann avatar image
yann answered ·
As said, per current you need at least 3. Then you can add more if you have enough PV available to charge
nickdb avatar image
nickdb answered ·
Do not size for max battery current, the continuous rating is most likely what the BMS will send to the inverter as a limit.
The current specs have a recommended discharge rating of 56A, it would be advisable to rather use this for a 24V system. 4 modules would be my preference.
Battery Compatibility
Victron Pylontech battery compatibility guide
