Paul Simon avatar image
Paul Simon asked
Phoenix Inverter 12/500 defective?
Hello! Since yesterday the Phoenix Inverter 12/500 in my van is constantly going into low voltage shutdown mode after a short while although the battery (100Ah LiFePo @ 13.5V) is nearly fully charged. In the Victron Connect App the device is showing a wildly fluctuating battery voltage as long as its running - eventually triggering the low voltage protection. The inverter is connected to the battery by 0.5m of 6mm² cable as prescribed in the instructions, no fuse. I checked the cabling and everything seems to be just fine. Since the device was working flawlessly in exactly this setup for one and a half years I have come to the conclusion that it must be faulty and needs to be replaced (or repaired if possible). What do you think? Any advice appreciated!
A load (laptop power adapter, approximately 75 Watts) is connected to the inverter at about 10s into the video:
And another one:
Phoenix Inverter
Paul Simon answered ·
Okay, my bad: While double checking the cabling for the second time I noticed that one of the terminals on the inverter had come a little loose. Most likely by vibrations from driving the van. After tightening the screw as much as I dared the problem is gone now.
I really wish that Victron used a little sturdier terminals, though. Same goes for the MPPTs. Why not simply provide M4, M6, M8, M10 studs depending on Amperage?
Regular checks and maintenance would still be necessary. This is true of most electrics. Yours has the added issues of vibration which has a way of working things loose. So does thermal cycling.
