tigrecito avatar image
tigrecito asked
NMEA 2000 MPPT and BMV show Battery 0 and 1
Hi, BMV has 2 batteries attached. Normal battery and starter battery. Voltage and current is properly pushed to NMEA 2000 as battery 0 and battery 1. As soon as I connect a MPPT, battery 0 and 1 also show values from MPPT.. so they are mixed. NMEA display now shows both values and switching them. For example at night my battery 1 shows always flashing voltage between 13V (voltage of starter battery) and 0.01V (Voltage of solar panel)
Any idea what to do? I would like to see the MPPT values in NMEA network-but not always as flashing values.
cerbo gxBMV Battery MonitorMPPT SmartSolarNMEA 2000 - N2K
tigrecito answered ·
I found something out: I used dbus-spy in shell to change the data instance of mppt .
now it is working as expected.. I just wonder if there is anything which can be broken now?
regarding manual it is not advised to to so .. what could be a possible impact of this solution and how to check if I have a problem?
