Does anyone have a diagram for how to set up the smart shunt with a parallel set up? I have two 115ah Batteries set up in parallel in my camper and want to add a shunt to monitor. The diagrams in the manual are only in series or I missed it.
Cheers
Cheers
The shunt must be installed into the combined minus path like this
+-----------------+ | | +----| + Battery 1 - |----+ | | | | +---------+ | +-----------------+ | | | <----+ +-----| Shunt |----> to loads/chargers | +-----------------+ | | | | | | | +---------+ +----| + Battery 2 - |----+ | | +-----------------+
Simply consider both parallel batteries as a single huge one. Just draw a virtual frame around both batteries and forget that there are actually two batteries inside that frame.
Simple mark up. Best to take the feeds from opposite batteries.
48 People are following this question.
