Richard Pearce avatar image
Richard Pearce asked
SmartSolar MPPT no longer showing on VRM
I’ve had a SmartSolar MPPT connected and functioning correctly on a system using a VE direct cable to a Venus GX. Initially all was well but at some point the reporting seems to have been lost onto the VRM. With the solar disconnected the blue bulk light flashes and is solid with solar connected. This is DC coupled in a system which also has a Multiplus 2 and a Solis AC coupled solar inverter on the input side. I’ve today checked all wiring and changed the VE direct cable over to port 2 on the Venus with no change. The MPPT shows as charging but is just not reporting on the VRM. My next move is to try another VE direct cable, unless anyone has any suggestions. I’ve read all the other threads I can find on this to no avail.
VRMMPPT SmartSolar
matt1309 avatar image
matt1309 answered ·
Hi @Richard Pearce
Just to confirm is it just not showing in VRM or not showing on the local web view as well?
ie if you go to http://venus.local when on the same network/wifi as the gx device.
Then press space/enter the menu.
Can you see the smartsolar MPPT in the devices list here? If not then I agree sounds like a cable might be at fault, especially if the MPPT seems to be working. (to check all is working it may be worth using victron connect app to connect via bluetooth to the MPPT just to check all is as it should be).
You could also check devices under device list on VRM. It'll likely show when the connection disappeared, might give you a clue as to when the issue arose/what might have caused it.
Richard Pearce answered ·
Hi @matt1309
Thanks for your response. I’ll get the customer to try connecting as you’ve suggested when he’s next on the same network over the weekend.
This happened with no change from the customer to the setup around 6 months ago as it indeed has disappeared from the device list on VRM. Just picking this one back up after a bereavement with the customer.
Will report back.
Hi @matt1309
Ok, some progress on this.
The MPPT doesn’t appear in device list if accessed on the local network. Using Bluetooth everything is reporting normally.
Having moved the VE direct cable from input 1 to input 2 on the Venus GX, there was no change so I’ve sent a replacement VE Direct cable which should eliminate that. Then it’s down to input on the Venus GX or output on the MPPT. And I guess the only way to check that is to swap the Venus GX for a new unit, likely a Cerbo.
Will update when the cable is changed.
I have to say, I’m no big fan of the VE Direct connectors.
Hi @matt1309
New VE Direct cable installed. :-) No change. :-(
So I guess options are,
1, Update firmware on the Venus GX if available.
2, Update firmware on the MPPT if available.
3, perform a factory reset on the GX
4, try another GX device.
If none of that works, is there a way to test the VE direct side of things?
Thanks in advance.
Hi @Richard Pearce
Regarding "If none of that works, is there a way to test the VE direct side of things?": What you can do is attach a VE.Direct USB cable between the MPPT and a PC (windows/mac) and use the windows/mac version of VictronConnect to check whether there is communication on the MPPT's VE.Direct port.
Kind regards,
Thiemo van Engelen
Hi @Thiemo van Engelen (Victron Energy staff)
Thanks for that. I’ll have to get hold of a VE direct to USB cable.
Is there a way to use the same cable to test whether the Venus GX is communicating ok?
Hi @Richard Pearce
Unfortunately not with a regular VE.Direct USB cable, because the isolators that are both in the cable and in the Venus GX don't get any power (which it normally supplied by the MPPT).
Kind regards,
Thiemo van Engelen
