sesshoumaru avatar image
sesshoumaru asked
Extending Pylontech battery bank
Hi @ all
I have a system with 8x Pylontech US2000C batteries, which are connected with 4 cables to a busbar.
I am planning to extend the system with two more US2000C, which will also be seperatly connected to the busbars. Can I just hook the new batteries up and start them? Or is there something more to consider? The SOC will definitly be different e.g.
Thanks
cerbo gxLithium BatteryPylontech
Alexandra avatar image
Alexandra answered ·
@Sesshoumaru
Pylontec claim their batteriss can handle different SOCs, so technically you can. Their manuals dont include any special methods foe connecting new batteries to a bank.
Just make the new ones the master.
I personally prefer them to be at least the same voltage. But will usually charge and balance both banks before combining them.
9 comments
sesshoumaru avatar image sesshoumaru commented ·
Thanks. I plan to upgrade the second bank to 8 batteries as well (own 250A breakers).
I have no special equipment for balancing, so I will just throw them together hand have them doinig their thing, I guess.
kevgermany avatar image kevgermany ♦♦ sesshoumaru commented ·
I did this with mine (US5000), was in a hurry and had no other option. @Alexandra would not be impressed and I fully support her recommended method. But it worked. In fact the lower charged batteries seemed to be charging from the full one when there was no external charger.
nickdb avatar image nickdb ♦♦ kevgermany ♦♦ commented ·
Yip, this is why the recommended procedure in the docs is to leave the batteries on but isolated from the inverter until the LEDs have balanced.
sesshoumaru avatar image sesshoumaru nickdb ♦♦ commented ·
I thought its not a good idea to disconnect the batteries from the inverter.
I mean I do not plan to power the system down. I assume tne new batteries will be loaded to 50% and I would wait for the current battery bank to reach 50% to smoothly connect them -- while is all up running.
nickdb avatar image nickdb ♦♦ sesshoumaru commented ·
The inverters would be powered off.
Nah, the entire house runs over them. Cannot power them down.
Alexandra avatar image Alexandra ♦ sesshoumaru commented ·
Unless there is someone on life support in your home there is no possibile reason why a short 10 or 15 minite shut down cannot be managed.
Your next planned upgrade should be a system bypass installed for maintenance/upgrade or repair reasons.
I cannot over emphasise how freaking dangerous working on a live battery bank and system is.
There are literally thousands of amps available waiting for a small mistake.
sesshoumaru avatar image sesshoumaru Alexandra ♦ commented ·
@Alexandra
The system has a bypass, I am just reluctant to use it for just adding a battery to the DC side. And yes, there are running some very important servers which of cause have their own power backup, but never try a system without need.
All the more reason to have a bypass in. All our systems that run servers have them.. what happens if athere is an unrecoverable error inverter goes down and the only way to repair is a shutdown and replace.
You would then need to switch to an alternative power source.
