tx......
appreciated.
you should not be getting that sort of voltage drop even without pre charging the capacitors - if you are something cant supply the required current, so there is stil a underlying issue. ie the batteries bms is turning off, or cable size. or even a high resistance connection.
if its the battery's bms then as long as you are aware then the pre charging is fine
108 People are following this question.
