larryb avatar image
larryb asked
VictronConnect and Multiplus with MK3
I am totally confused. I seem to read that I can connect to my Multiplus with VictronConnect through my new MK3-USB(it is recognized and updated), but it shows No Device. Works fine with VictronConfigure. I have not downloaded the Beta, is that why? Any reason to even use Connect?
VictronConnect
nebulight avatar image
nebulight answered ·
Unless something has changed, you need a Venus device (color control GX, Venus GX, ect) to connect.
EDIT: I need my coffee. I read that as VRM.
larryb avatar image larryb commented ·
The Connect manual indicates that you can connect to a Multi with the MK3, but a bit more reading infers that the Beta version might be needed. I cannot tell and that is why I am asking. Thanks
Larry
nebulight avatar image nebulight larryb commented ·
I need coffee. I thought you meant VRM. My mistake. I'm not sure about using the windows version of Victron Connect with the MK3.
UPDATE -
VE.Bus / vebus MultiPlus programming is now supported with VictronConnect -
https://docs.victronenergy.com/victronconnect-vebus.html
OLD MESSAGE -
Yes, making changes on a MultiPlus with an MK3 in VictronConnect is a feature that is currently in a public beta.
It is still recommended to use VE Configure for now.
If you wish to try the beta in a suitable test system, you can find out more here:
https://www.victronenergy.com/live/victronconnect:beta
njsarn avatar image njsarn commented ·
Hello Guy, I have a Multiplus 12/2000/80-50 12V . Can I use a VE Direct to USB cable with VE Configure SW? Or do I need to use MK3 to USB cable (awfully expensive).
Matthias Lange - DE avatar image Matthias Lange - DE ♦ njsarn commented ·
The Multiplus C 12/2000/80 don't have VE.Direct. You need a MK3.
njsarn avatar image njsarn Matthias Lange - DE ♦ commented ·
Thank you much.
