Jordy avatar image
Jordy asked
Cerbo GX make my own digital multiplus switch
I would like to use a original switch on my boat to turn the inverter {on/off/inverter} like the switch on the quatro. I have the Cerbo GX. Can I use a digital input or something else to setup this "switch"
I know there is the digital multiplus panel with the same function so maybe someone can advice me
MultiPlus Quattro Inverter Chargercerbo gxDigital Multi Control
derrick thomas avatar image
derrick thomas answered ·
You could use the digital inputs (you would need 2, one for inverter position and one for charger/passthru only) with a node red flow.
Jordy avatar image Jordy commented ·
Great thanks for the reply, if I use this inputs where to setup the value so the GX turns it into action
derrick thomas avatar image derrick thomas Jordy commented ·
Use node red (Venus os large)
Jordy avatar image Jordy derrick thomas commented ·
Looks so interesting, I have been trying to find a similar project to pick it up from there, but I cannot find a similar one.
I am thinking to control the state of the quarto by a rotery swisch (0,1,2)
0 off
1 inverter
2 charter only
You say there is a way to use the relay for it, but can I use the relay as a input?
Or do I need to use the IO input?
My concern is that there is no good input for this..
Maybe you have some tips where to look
chrisrbg avatar image
chrisrbg answered ·
You could use "guimods" and get after configure by click on the MP the switches:screenshot-2023-08-19-225621.pngscreenshot-2023-08-19-225636.png
