David Gould avatar image
Disconnect AC In when battery is charged on Quattro
I want to be able to disconnect the AC in on my quattro when the battery is charged enough to support the load. it is a 15kva quattro with 38.4kw of useable lithium,
MultiPlus Quattro Inverter Chargerinstallation
David Gould answered ·
Hi Guy
I have installed an additional Quattro running in parallel. When I try and run the PV inverter support it will not let me with ESS and if I don’t us it the fronius inverterS don't come online, any ideas please.
Hi Guy
I have this working but want to be able to connect the ac in when the battery is at 100% so I can export but have it disconnected between 30and 99%. The assistants work on an or basis which means I can do both. Can you help please.
Hu Guy
Thanks for the reply. What I failed to mention was I am running ESS assistant.
This functionality is available.
If you are using VEConfigure:
https://docs.victronenergy.com/veconfigure.html#ignoring-ac-input-with-virtual-switch
If you are using the VE.Bus enabled version of VictronConnect:
https://docs.victronenergy.com/victronconnect-vebus.html#ac-input-control
