topiflex avatar image
topiflex asked
Lynx Smart BMS - W-B01 and W-B06 (Low Cell voltage and Load will disconnect)
I have an issue with a prealarm on my LYNX-Smart-BMS500.
When I enable the prealarm function on the LYNX BMS I immediately get the message:
I have a LynxBMS, four 12V 300Ah lithium batteries,three distributors, Quattro, Inverter and two MPPT 150/85 (all Victron)
Batteries are balanced, all cells at 3.35V, SOC at 100% and when I keep the pre-alarm enabled nothing switches off even after hours, but the prealarm persists.
I am never getting an alarm in this case (A-B01 or A-B06) and everything is working properly.
What could be the reason for the prealarm? Maybe my batteries (build 2019) have a communication issue with the new BMS? The problem occured when I changed my BMS from VE Bus BMS to Lynx Smart BMS
BMS
