demderder avatar image
demderder asked
Issue with power reading when powering a PC speaker from inverter
To start, the shunt is wired in the correct direction and there's no loose connections.
When I plug in my PC speaker system the 24/800 phoenix is displaying more power being consumed than whats actually passing through the shunt. I've removed the MPPT to make sure I have no side power and I isolated loaded to identify the device draw.
My system has a 3w dc load for my raspberry pi. When I turn on my inverter with no load the inverter says 0w and the shunt says 10w. So far all correct. I plug in a load and the shunt says 150w and the inverter says 144w. Still correct because I know some power is lost while inverting. The problem is when I plug in my speakers, The shunt says 13w but the inverter says it's producing 25w. Makes no sense because the inverter can't output more than what's passing through the shunt. I measured the line and there's 13w passing through. I even let it run for a set amount of time and the batter percentage fell like there was a 13w load, mot like a 25w load.
Why would the inverter show a higher power output than what's passing through the shunt when a speaker is plugged in and not with any other load? Maybe it has something to do with the speaker system's amp or capacitors.
Phoenix Inverter
Alistair Warburton avatar image
Alistair Warburton answered ·
At that sort of load, IE very small, the measurments, in my experiance, are not great. The PC speakers likely have a very poor power factor and a high switching frequency which is confusing everything.
