I have two Quattro 48/5000 running in parallel. For the AC Current Limit setting, editable on the Cerbo display, I can adjust it down but it just resets back to 26.2A when I press Accept.
Thoughts on what I’m doing wrong? Thanks!
Here’s a picture of the Quattro control panel. If i try setting it to 10a, for example, I get an error message.
Like seb71 said, the minimum input limit per inverter for your model is 13.4, you have 2 in parallel so it's doubled. (Yes I know the math doesn't add up exactly, it is an approximation.)
99 People are following this question.
