Hi ,
I just figured out, that my BMV in the Bluetooth App shows only the product information page. I cant see any battery status anymore.. The display still shows normal values...
Does anyone know what happend? Here the app screen :
Hi ,
This means that the internal Bluetooth dongle is not able to communicate with the battery monitor part. First thing to try is to power cycle the BMV by disconnecting the grey cable in the back for 2 minutes and then reconnect it. When it then still has this behavior, it is probably a hardware failure, in which case you should contact you seller/distributor to apply for warranty.
Kind regards,
Thiemo van Engelen
56 People are following this question.
