dozzerfolly avatar image
dozzerfolly asked
Victron smart shunt
Hi all, I recently purchased a Victron smart shunt and had it fitted by my local 12v company, when I looked at it when I got home I can see the red power cable has been connected to the leisure battery terminal of the split charge relay because it was closer rather than the positive terminal of the battery , the negative side of the shunt is all correct, will this affect the voltage readings?
SmartShunt
Mike Dorsett avatar image
Mike Dorsett answered ·
smart shunt actually should have 2 voltage inputs - one for the starter and one for the leisure battery. If only the leisure battery has been wired, then you will only see the voltage from that battery.
