So what are the reasons that the Orion Tr is not recommended for use to charge a lithium leisure battery from a standard old school alternator....
Even if you limit the output voltage to 13.8/13.9v....?
As written in the Datasheet, all ADJUSTABLE Orion-Tr CAN be used as charger (I do the same with a 24/24-12) and it works fine for acid batteries, but I would not dare to charge Lithium batteries.
62 People are following this question.
