I just bought the Smart Shunt and would appreciate if someone could help me with the correct settings on the App for an AGM batterie.
Thanks
Thanks
You can (almost) leave them untouched.
Change the capacity to match your battery though.
At the end of your first charge up, just check the synchronisation there. You may possibly need to adjust charge voltage. It does depend alot on your battery charge needs and your charger settings and ability.
But we can see later on. Just @ on this thread...
47 People are following this question.
