I have the Multiplus-II 48/3000/35 and the recommended battery capacity range is 100-400Ah. Is it safe/possible to use 24 - 510Ah 2v batteries with this?
Depending on your use case YES it is.
I am Off-the-Grid and run currently a singel MultiPlus-II 24/5000 on a 2940Ah battery, which give me roughly 5 days autonomy without ANY solar and wind power.
However, if the battery is once empty, I need a realy tough GenSet to charge this Dinosaur.
With ONLY ONE MultiPlus-II 24/5000 it take 36 hours to get the Batteries full again, hence I want to get a second MultiPlus-II and a bigger GenSet or use DC charging direct from a Yanmar Ship Diesel 35HP and a 280A Alternator. Oh, the Yanmar has a lower fuel consumption (less then the half) as a 6000kVA standard portable GenSet.
You can register any bodybuilding contests, you'll win all prizes xD
Should be 6000VA.
My current Hatz Diesel 1,9kW 28V 68A with electric starter has 150kg.
43 People are following this question.
