Dan Markham avatar image
Dan Markham asked
Phoenix inverter - Not powering the VE.Direct Bluetooth Dongle
Just setting up a phoenix inverter 24|800. It's working just fine and Inverting like a champ. So I am trying to add a VE.Direct Bluetooth Smart Dongle. This dongle does not power up (no lights) what plugging it into the phoenix. To test I plugged the dongle into the MPPT 100|20 it lite up and was seen just fine, and I updated the firmware. Still no lights when I plug it into the phoenix
So my question is what am I'm doing wrong when trying to add this to the inverter?
Phoenix Inverter
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @Dan Markham
It sounds like a hardware problem with the VE.Direct connector on the Phoenix Inverter. Can you check the pins whether they not bent?
When everything looks ok, I would advice you to contact the seller to have it replaced under warranty.
Kind regards,
Thiemo van Engelen
Dan Markham avatar image Dan Markham commented ·
With just a little bend on the pins it now stays connected perfectly.
