tomskk avatar image
tomskk asked
Generator charging current on Multiplus II 48/3000/35 with SimpBMS
Can anyone advice how/where to setup the max charging current from generator to battery (Tesla BMS 12S). I have modified the settings in VE.Configure for Multiplus in Charger setting to 35A, and also in SimpBMS - max charge current to 35A, but i only get 25A to charge my batteries via Multiplus.
I have a 8000kW generator single phase, connected to Multiplus ACin.
Is there some other setting that might interrupt my request for 35A ?
Multiplus-IIBMSGenerator
Jason - UK avatar image
Jason - UK answered ·
@tomskk can you increase the A/C voltage on your generator? If so, does that make a difference? I believe the charger performance is based on 230v input, 35 amps output at 48v whereas your AC voltage is 224v. I wouldn't expect 6v less to make that much of a difference but worth checking.
Marc Heymans avatar image Marc Heymans commented ·
Is it not limited in the GX device, under DVCC or the battery parameters?
tomskk avatar image tomskk Marc Heymans commented ·
Under DVCC i can't find any option to increase Amps. BMS is limited to 35A for battery charging. If i disable DVCC in GX then it goes to 35 Amps, but then the system behaves strange.
the-doon avatar image
the-doon answered ·
I had a similar issue with my setup. Someone on here suggested I may have had weak AC turned on. Yes I did and this was the cause of my reduced charge current.
