Franklin Bravo avatar image
Franklin Bravo asked
Victron Quattro+Pylontech Force L1 System
I have a Victron+Pylontech backup system, which randomly without failures in the AC supply network, first the low voltage battery alarms appear, high discharge current and the entire system shuts down for 3 minutes. I understand that the BMS of the batteries is the one that controls the operation of the system. Is this true?
PylontechBattery Protectfault
tnt369 avatar image
tnt369 answered ·
First check the reason for the high discharge current.
Franklin Bravo answered ·
There is no indication or cause of high current, no fault, no power consumption, no high temperature. This has occurred even under conditions of minimum consumption.
tnt369 avatar image
tnt369 answered ·
Please more information about your system (what components and how many, connect to grid ...).
tnt369 avatar image
tnt369 answered ·
Thank you for your valuable help, we updated the battery firmware and the fault disappeared. The update is done by Pylontech via the internet. We still do not know the technical reasons for this failure.
Victron Pylontech battery compatibility guide
Victron BatteryProtect product page
Faults with Victron equipment are best discussed directly with your dealer - this can be formalised with this support request form.
