sebastia avatar image
sebastia asked
How can I interface Third Party "HK-LW-312-20 6.6kW CAN" Chargers with CerboGX?
Hello, I am wondering if it is compatible to connect three "HK-LW-312-20 6,6Kw CAN" third party chargers to the Cerbo GX and then read and write the data through ModbusTCP. If so, would I connect it to the VE-CAN? And which registers would I have to read?
Now I have the chargers connected to the VE-CAN port of the Cerbo GX, but it doesn't recognize the chargers.
The chargers use CAN communication 250kbps and the following CanID's: 0x18FF50E5, 0x1806E5F4.
cerbo gxcharger
hackerp avatar image
hackerp answered ·
I have the same problem. Trying to connect third party lithium battery chargers to the Cerbo GX but it doesn't recognize them. Connecting it through VE-CAN and trying to read from registers 2307 to 2322 through modbus TCP but doesn't work. Anyone?
The devices need to support the messaging that Victron uses over CAN. Until then I wouldn't be connecting unsupported devices to the same bus.
Louis, in the modifications section, has a serial driver you can use to try manage the battery.
Jan Brož avatar image
Jan Brož answered ·
any progress on this? I would like to connect a MW NPB-1700-24 battery charger to my system to increase grid charging capacity(phoenix chargers are just too expensive).
