topiflex avatar image
topiflex asked
Multiple ATD conntections to LYNX-BMS possible?
I would like to use more than one Smart Battery Protect (SBP) in my Victron system. I am using a LYNX BMS and have only one H-Signal on Pin 6 which is connected to my first SBP. How can I connect a second SBP to the ATD pin on LYNX-BMS? Is it possible to use a busbar? How can two or three SBPs work independently in this case? Will all SBPs be switched off if one gets disconnected by the BMS?
Battery Protectlynx bms
klim8skeptic avatar image
klim8skeptic answered ·
@Topiflex the ATD relay has a max current of 0.5a. enough fur 2 SBP's connected remotes to the ATD port.
topiflex avatar image topiflex commented ·
What about two additional Cyrix relays? Will this be too much for the ATD relay? And if yes, how can this issue be solved?
klim8skeptic avatar image klim8skeptic ♦ topiflex commented ·
Cyrix relays?
I'm sure if you look through the data sheets you will find how much current is required to activate them.
topiflex avatar image topiflex klim8skeptic ♦ commented ·
Yes. But how can I handle all the SBPs and Cyrix relays with just one ATD conntection on the LYNX. I guess I am not the only person who had the same question. How do people solve this issue? For expamel Two Cyrix relays, tho SBPs - just one ATD contact on LYNX BMS
