gabius avatar image
gabius asked
Steps to follow to add external metter
Hello folks !
I'm having an issue with my Multiplus 2 wich draw current from grid sometimes when it should not.
Because i have loads on the AC-IN and pv inverter ( i dont care to have any info on this side but anyway) someones told me that i have to install a Smart metter to resolve this problem.
I have a shelly on each phase (3EM) so i used it with victron.
I want to Be sure that i all setup correctly,
1 The shelly apears in the cerbo GX as a normal smart metter
2 I have the info on each phase L1 L2 L3
3 I set my ess to " external current metter" in the ESS section
4 In VE configure i set "external current metter" in the first page, but do i have to create an assitant for it (like the ESS) and so how ?
My house is a 3 phase but my multiplus is only on one phase (by now) and powering only a room. the solar surplus is fed ( on one phase) back in my house where there is loads and a 3 phase inverter ( huawei).
I export the whole surplus on th GRID.
I know that it's a bit difficult to understand my whole instalation, and that i make a lot of mistakes in English, so If needed i can draw the whole system.
Multiplus 2 5000Va
Cerbo GX
Mppt Smart solar 150V/30A
Pylontechs Us2000C x4
Shelly 3EM ( SETUP between The GRID an the house)
Thanks for your helps guys
ESSEnergy MeterVEConfigure 3
