vanlifeftw avatar image
vanlifeftw asked
inverter/charger + additonal charger recommendation
Hello!
For my mobile install, I have the cells to assemble 608Ah of 24V battery storage. (2 x 304Ah 24V in parallel). The recommended charge and discharge rate is .5C. I believe the maximum charge rate of the 24V multiplus ii 2 x 120 is 70A. 70A seems pretty far from the 300A I could be charging at. Is there another Victron charger I could use in parallel with the multiplus? Using 2 multiplusses seems a waste because I wouldn't need the additional inverter.
(My reasoning for using 2 x 24V instead of a single 48V was to have some redundancy, in case there was an issue with one of the BMSes. I realize that if I constructed a 304ah 48V battery, the 48V multiplus would effectively double my charge rate and get me half way to .5C.)
Multiplus-IIbattery charging
What will your charger be powered by? AC/Alternator?
vanlifeftw avatar image vanlifeftw kevgermany ♦♦ commented ·
Thanks @kevgermany , I didn't see this comment section earlier. It's powered by AC.
vanlifeftw avatar image vanlifeftw vanlifeftw commented ·
More specifically, 110VAC and possibly 220VAC 60hz
kevgermany answered ·
Any of the AC chargers can work this way. The IPxx chargers are waterproof, depending on the rating. Not too bulky.
