hjoerg avatar image
hjoerg asked
SmartShunt IP65 500A/50mV - Configuration Items
I installed a shunt ,SmartShunt IP65 500A/50mV with following Firmware, (V4.14 or 2.43 ?? ) my initial setup gives only the option battery capacity, and the second optional settings are additional devices.
But not further configuration items seen like the manual shows - e.g. charge efficiency factor and so on - also the capacity could not be changed
Is this correct, maybe at the new firmware versions ?
I'm using a Renege 50Ah LifePo4 Battery and it seem the battery SoC Status not really shown the right value, or the battery capacity not measured correctly
thanks
SmartShunt
pwfarnell avatar image
pwfarnell answered ·
Is the Smartshunt set up as a "DC energy meter" which would explain seeing the option of additional devices. Go to the settings menu (small cog wheel), then select misc, then for the "monitor mode" option make sure that this is set to "battery monitor" not "DC energy meter".
hjoerg avatar image
hjoerg answered ·
prefect that's the point - I my first run, I selected none instead of misc
thanks
