zygao avatar image
zygao asked
Solar panel charger power very unstable
The solar charger power very unstable, The MPPT is smart 250/100 VE.CAN, the SOC of house battery is 70%. What is the reason ?1688084541984.png
MPPT SmartSolarSolar Panelsmart solar charging behaviour
zygao avatar image
zygao answered ·
When the state is "Foat", the charger is very small. When the state is “External control”,the charger power is high. I don't understand why the state is changed every some seconds ?
If it is communication problem ? But there is no alarm on GX touch panel.
nickdb avatar image
nickdb answered ·
You need to see if the entry on the GX is disappearing, it won't generate an alarm. Might be a bad cable. Make sure you aren't using both a cable and smart networking, these can conflict and aren't intended to be used together.
zygao avatar image zygao commented ·
Thanks very much, I find the reason. I run a new VE.DIRECT cable, now it is OK.
herzigwi avatar image
herzigwi answered ·
I see something similar on my configuration. The drops on my case are just clouds. Looks the same.
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
