djsmiley avatar image
djsmiley asked
Victron SmartSolar with Cerbo and charge disconnect simultanously
Setup:
Victron Smartsolar 100/30 with VE.Direct remote cable connected to a Smart BMS CL 12/100
However, this means the VE.Direct port is occupied, so can't be used to connect to the Cerbo as well.
What are the options to connect this so the solar can be monitored using the Cerbo?
Any other options apart from installing a Cyrix-Li-Charge or Smart BatteryProtect to free up the VE.Direct port?
cerbo gxVE.Direct
