Chad Petersen avatar image
Chad Petersen asked
multiple cerbo gx to connect 6 mppt 150/35 solar controllers
The project that I am currently working on has 6 mppt 150/35 smart solar controllers. I would like to have them all being monitored using the cerbo gx and Victron Connect. I would like to use VE.Direct to connect all 6 smart solar controllers. Would it be possible to add an additional Cerbo GX on the same network, giving me the additional 3 VE.Direct ports needed to monitor all 6 mppt smart solar controllers.
cerbo gxMPPT SmartSolarVE.Direct
Use VE.direct to USB cables and a USB Hub to connect all to one GX device.
https://www.victronenergy.com/accessories/ve-direct-to-usb-interface
Chad Petersen avatar image Chad Petersen commented ·
I have one issue with connecting them all through USB, I am also using the touch that uses one of the USB ports.
Chad Petersen avatar image Chad Petersen Chad Petersen commented ·
Sorry I didn't fully comprehend you comment the first time I read it.
your saying that I can connect a simple USB hub into one of the ports and expand my USB ports.
shaneyake avatar image
shaneyake answered ·
The correct way to do this is to get USB to VE.Direct cables and connect the other 3 via those cables. Also allows the system to know what is really going on as the Cerbo can see all the controllers.
If you did add a another GX, it will show up as a new site in VRM, not the same site.
shaneyake avatar image shaneyake Chad Petersen commented ·
You can buy a simple USB hub to give you more USB ports.
the-doon avatar image
the-doon answered ·
I believe the USB for the touch is only to power it so you may be able to use a hub to make that USB port accept your 6th MPPT. I also remember something about that 3rd USB being changed so you’ll have to research whether it’s still a functioning USB or just a dedicated power only for the touch.
the-doon avatar image the-doon commented ·
I just had a read of the Cerbo manual and that 3rd USB is now power only for the touch. But as Matthias is saying you can use a hub which will let you connect up to 15 VE.Direct devices.
