Can I use BatteryProtect 12/24V to prevent lithium battery from discharging the lead-acid (LA) battery? In other words connecting the lithium to the "IN" terminal and LA to the "OUT" terminal of the BP.
The BatteryProtect is not designed for that.
You can't prevent to high or reverse current.
39 People are following this question.
