I am in the final assembling of all my Lynx devices before running the cables and I'm not sure if I should use carbon conductive paste both at the bus bars junctions and/or on the fuses' faces.
Any help from you guys is greatly appreciated
Probably not a good idea.
Thanks,
I'm not happy with the poor and uneven finish of the Lynk's bus bars, they are not machined flat enough to offer good contact with each other nor with the fuses and I've heard several complaints of units heating up excessively so I thought it would indeed be a good idea.
I'd just like to know if anyone has used it
It's better to not add anything between contacts. If something clean with very fine file / sandpaper and wipe with clean solvent (alcohol/IPA) and immediately attach. With coated surfaces as Lynx and fuses that is not so important but open copper joints it's very important.
In some rare exceptions you can add non conducting vaseline externally to cover contacts after tightening. That can protect metal from moisture/salt/fumes etc.
"If something clean with very fine file/sandpaper" . . . as an engineer I would never do that in the proximity of electronics but most importantly I would not be able to guarantee a perfectly flat surface nor could anybody else. Besides the bus burs appear to be plated so it's a no-no-go on that score.
All lithium battery bus burs are carefully cleaned and coated with this very expensive conductive paste, I have seen resistance tests showing great improvement.
Yes, I have also got the conductive/ insulating grease to lay on top after the connection is made and torqued.
https://www.youtube.com/watch?v=fL1BMKKcvYY
https://mgchemicals.com/downloads/tds/tds-847.pdf
41 People are following this question.
