I am going to install lithium and the max charge rate is 50amps. Can I parallel a 30 and a 20 to get the 50?
Yes, make sure both have identical settings. Otherwise one will interfere with the other.
Also check that your supply can handle the load. If it's an alternator and you're near its max output, it may burn out.
Victron DC to DC Converters Product Range
__________
32 People are following this question.
